Adding Manning Number
At the Muster List Setup window, click Add New.
Enter all of the required fields in the Definition tab using the drop-down list.
Navigate to the Emergency Duties tab and define the type of duties for the Safety Number by selecting the Safety Group, Safety Role, Safety Role, Safety Function and Muster Station from the drop-down list.
Navigate to the Eligibility tab and select the mandatory requirements, courses/certification and Operational Position by selecting the respective checkboxes.
Click Save to save the Safety Number.
Duplicating Manning Number
You can duplicate a Safety Number when the majority of the information is the same.
Select the Safety Number from the Search Panel and click Duplicate.
Update the necessary information and click Save to save the record.
Deleting Manning Number
You can delete a Safety Number that is not in use, simply by selecting the Safety Number and clicking Delete.
