Disabling a Posting
Repeat step 1 of the above.
Enter the reason to disable the posting when prompted, either by selecting a predefined reason from the drop-down list or by entering them manually.
Figure 7-33 Predefined Reason to Disable Posting
If Allow manual postings is selected, this only disables postings through the interfaces. Manual posting within the Crew Handling window is still permissible.
Click OK to set the posting status for the account to a No or Manual.
Figure 7-34 Manual Posting Allowed Status
