Editing a Reservation
Search the reservation using the Search Panel, then click Edit Information under the Crew Info tab to open the existing Reservation Form.
Edit all relevant information, and click OK to save the changes.
Cancelling a Reservation
Select the Expected crew from the Search Panel, and click Cancel Reservation under the Crew Info tab. You can only cancel an Expected crew reservation.
Selecting Yes at the Cancel Reservation prompt places the booking under the Cancelled tab.
