Exporting an Invoice
Exporting of invoices to other file formats is possible. Supported file formats are: Acrobat Format, Crystal Report, MS Word, MS Excel and more.
Repeat steps 1 to 2 of Printing an Invoice.
  1. In the Print tab, select Export.
  2. Select the file format and destination type from the drop-down list when prompted.
  3. Select the page range to print.
  4. Enter the file name and location path when the system prompts for file saving location.
