Quick Effects Assignment
The Quick Crew Effects Assignment allows you to record crew’s personal effects for single/multiple accounts.
Figure 7-21 Quick Crew Effects Assignment
This figure shows the Quick Crew Effects Assignment
  1. From the Quick Functions file menu, select Quick Effects Assignment.
  2. In the Account Identifier section, select Search by Cabin Number or Search by Safety Number.
  3. In the Additional Information section, Count field, enter the number of items, select the Transaction date using the date editor and enter a remark if any.
  4. Select the Crew Effects item by selecting the item checkbox. Multiple selections are allowed.
  5. Click Assign to assign the items or click Assign & Print to assign and print at the same time.
  6. Select Clear fields after assigning to clear all details after completing the assignment.
