Search Panel
The information displayed in the Muster List Setup is managed using the filter selection of the Search Panel, for example, filter by Safety Department, Safety Group, Muster Station, Safety Position, In Port Manning (IPM group), Emergency Function, Life Boat, or Life Raft.
Figure 7-106 Muster List Setup Search Panel
This figure shows the Muster List Setup Search Panel
In the Summary Section:
  • You can see the total number of Required/Optional Safety Numbers Assigned/Unassgined
  • Active Safety Numbers has a check mark in the Active column.
