Open Session (Empty)
  1. At the ribbon bar, select Cashier Session.
  2. Expand the Cashier container by clicking the “+” symbol.
  3. Select the user name, and click Open Session (Empty) at the ribbon bar.
    Figure 24-8 Exchange Transactions with Cashier Session (Open Session)
    This figure shows the Exchange Transactions with Cashier Session (Open Session)
  4. At the Details section, select the Name from the drop-down list.
  5. In the Opening Amount field, enter the amount for the department code. Use the Tab key to navigate.
  6. Click Save at the ribbon bar. This changes the cashier session from Opening to Active and is reflected in the Sessioncontainer.
