Adding a Comment/Sub-Comment
  1. Click the Add Comment.
  2. In the Comment tab, select the relevant fields using the drop-down list.
  3. Enter the Reported By, Comment Description, Additional Cost and check the urgency and sensitivity, if any.
  4. Click Save to save the record. This places a Red Cross indicator on the Comment.
  5. When you select a Comment and click Add Comment, this creates a sub-comment, defaulting the heading the same as the main Comment Category and Comment Description, and they are not editable.
