Deleting a Message
- Search the guest account in the Search panel, and click Message at Guest Handling tab.
- On the Message form, select the message to delete and click Delete Message.
- At the Delete Message prompt, select Yes to confirm deletion of the Message or No to return to the earlier window. Once a message is deleted, it cannot be undone.
