Flight Assignment
Arrival/departure flight information and transfers arrangements are updated in the Flight Assignment section.
Figure 10-107 Flight Assignment in Other Information Tab
Adding arrival/departure flight details
- Click Add in the Other Info tab, Flight Assignment section.
- Select the Flight direction, Date, Flight Carrier from the drop-down list and enter the Seat No, Flight Class and Passenger’s Name.
- Click OK to save the record.
The Edit assignment only allows you to edit the Transfer Price, Number of bags, Bag Label, or Seat number.Figure 10-108 Edit Flight Assignment
Maintenance
The Maintenance section displays all maintenance task related to selected cabin, regardless of its completion status. These task are entered in the Maintenance module.
Guest Categories
The Guest Categories section displays the selected information from Edit Information, Guest Categories checkbox. The information is configured in Administration, System Codes, Guest Categories Codes.
Guest Categories / Other Information
The Guest Categories and Other Information section displays the selected information from Edit Information, Guest Categories checkbox and various fields in the Name/Reservation section.
