Front Desk Function
The Front Desk menu comprises functions such as Cabin Overview, Posting Overview, and Check-in/Check-out status, which provides a high level monitoring and overview of the operations.
Reports
The product is pre-installed with a set of operational reports. You can create and add customize reports through the Administration module, System Setup, Reports Setup.
Figure 10-1 Reports List
Printing a Report
- From the Front Desk file menu, select the Reports option.
- Expand the report folder in the Reports List section by clicking the (+) key.
- Select a report to print.
- In the Print tab, select the Selection/Criteria and relevant fields.
- Click Print or navigate to the Preview tab to preview before printing.
- To export the report, repeat the above steps and click Export.
