Resolving a Comment
- Select the main comment and then navigate to the Resolution tab.
- Enter the Resolved by (Person) and Resolution Description, and then select the Resolved checkbox.
- Click Save to save the resolution. This places a check mark next to the comment(s).
- Select the Resolved checkbox to set all sub-comments as resolved.
