Service Charge
The Ship operators might have a standard Service Charge value defined as an automatic charge to the guest account. This posting is typically performed using the Quick Service Charge Posting function. The value of the service charge is set in the Service Charge, Default Charge Amount, and Minimum Passenger Age parameter. The Service Charge function in Guest handling enables you to post the service charge manually or disable the automatic posting.
Posting a Service Charge
Disabling Service Charge Posting
From the Change Service Charge Posting Amount window, select Disable Service Charge Posting, and then click OK to save.
At the Guest Info tab, the Service Charge Amount changes to No Service Charge Posting.
