Discarding Confiscated Items
Figure 21-17 Discard Item
Click the Discard Item on the ribbon bar to list all confiscated items exceeding the maximum storage duration.
In the Search Criteria section, select one of the following options and click the Search button.
Select the type of information to display using the Item Type, Store Location, or Guest Type.
Slide the Only for Pax/Crew which had check-out to Yes to only show the passenger that has to check out.
To search the item with a barcode, enter the barcode in the Item ID field. To include items that were already discarded in the Item List, slide the Include Discarded Item to Yes.
Select the Discard Method from the drop-down list.
Select the item to discard, and click the Discard Item button.
At the confirmation prompt, click Yes to confirm.
Click OK to confirm the number of item(s) being discarded.
The Date Returned/Discarded and Discard Method columns are time stamped with the actual date/time when the system discards the items.
To undo a discarded item, select a discarded item from the Item List.
Click the Undo Discard button.
Click Yes to confirm and click OK to confirm the total number of discarded items. This removes the timestamp in the Date Returned/Discarded and Discard Method columns from the selected item.
