Setting up System Labels
Log in to the Administration module, select Administration, System Setup, and Labels Setup.
Locate the label codes CONF00 and CONF01.
Figure 21-5 Label Setup
Select the code and enter a new label description, and click OK to save. The label code CONF00 refers to the word Confiscate and appears on the following windows:
Setup menu ribbon bar.
General Setup: “Prompt Signature Capture when...”
Confiscate Item Setup.
Confiscate Item Discard Method.
Confiscate Item Location.
Ability to show the “Confiscate Item” button in Confiscate Item menu.
Overview window: Total Item Confiscated Today.
Overview window: Top 10 most confiscated item.
Confiscate Item: Confiscated Item.
Management module: Loyalty/Track It tab, Confiscated Item section.
The Track It program enables you to record confiscated items, their storage location, and when they are returned to the guest or crew.
