2 Creating Arrival/Departure Notice
The following section describes the steps to create the EBORDERUK file for submission.
  1. Run EBORDER UK.exe.
  2. Select eBorderUK Transfer, eBorderUK File Creation from the menu option.
  3. At the Create Arrival/Departure Notice screen, update all the fields required by e-Border and then click Next.
  4. Select and update all the mandatory fields in Default Embarkation Port, including the information of previous five ports and then click Next.
  5. At the result grid, click Validate Data to validate and ensure all information is sufficient for submission.
    Figure 2-1 Create Arrival/Departure Notice Validation
    This figure shows the list of data to validate in Create Arrival/Departure Notice.
  6. The system creates and saves the log file in the C:\Temp\APIS\EBORDERUK folder if the information supplied is insufficient. Review the log file and correct all missing data then repeat the above steps.
  7. If all the mandatory information is supplied and the data validation completes successfully, the systems prompt a confirmation message There is no missing/incorrect data. Do you with to proceed to file submission?.
  8. Click Yes on the confirmation prompt to continue.
  9. Select to submit the report either by file or web, and then click Process.
  10. The system prompts a message box once the submission is successful. Click OK to close the screen.
