Preface
The Check-In application is the front-end application that enables a crew member to perform a quick and efficient passenger check-in using a step-by-step process, capturing key passenger data, assigning a guardian to minors, reviewing payment methods, and facilitating the acceptance of Contract Terms & Conditions.
Audience
This document is intended for project managers, application specialists and users of Oracle Hospitality Property Management System.
Customer Support
To contact Oracle Customer Support, access the Customer Support Portal at the following URL:
Product version and program/module name
Functional and technical description of the problem (include business impact)
Detailed step-by-step instructions to re-create
Exact error message received
Screenshots of each step you take
Documentation
Oracle Hospitality product documentation is available on the Oracle Help Center at https://docs.oracle.com/en/industries/hospitality/cruise.html.
Revision History
Table -1 Revision History
| Date | Description of Change |
October 2025 |
Initial publication |
January 2026 |
Updated the Gangway Security - removed Gangway/Tender Menu |
| March 2026 |
| May 2026 |
