Modifying / Uninstalling Oracle Hospitality Cruise Property Management
Any modification or uninstallation are done through Windows Control Panel in a Maintenance mode. This would allow user to select the options to perform like add features, remove, repair or uninstall the product.
  • Database scripts are executed only if API option is selected during maintenance mode.
  • Database scripts execution will be ignored if the API option is unselected during maintenance mode.
  1. Start the installation program by right-clicking the CruisePropertyManagement_23.3.x.exe and select Run as Administrator.
    If you have already installed the application, the Setup would start in Maintenance mode. Choose one of the options presented.
    • Add Features: InstallAnywhere will guide you through adding features to the installed set. The feature will be disabled if it is already installed.
    • Remove Features: InstallAnywhere will guide you through removing features of the installed product. User can uncheck the product features (WebApp / API /Mustering) that need to uninstall. Checked features will remain installed.
    • Repair Product: This function repairs the features of installed product and checks if API services are installed. If API Services are installed, the Database Connection settings screen appears, prompting you to enter the API DB Password.
      The installer automatically encrypts the password before replacing the old password with the new, encrypted password, updates the configuration and restart the API service with the new password.
      If the API Services are not installed, the installer exists and display “API is Not Installed. Repair installation is only available for the API feature.”
    • Uninstall Product: InstallAnywhere will remove all the features that were installed during product installation. Files, folders and windows services will also be removed.
  2. Click Next/Uninstall and follow the wizard instructions.
