Membership Management
For details on completing the following configurations, refer to Guest Loyalty Programs in the OPERA Cloud Services documentation.
Membership Class
Only one membership class can be flagged as “Loyalty Program.”
Figure 6-1 Membership Class Screen
Membership Type
The name of this Membership Type must be entered exactly as "PTS."
For details on how to create a membership type, refer to Configuring Membership Types in the OPERA Cloud Services documentation.
Mark the membership as Primary.
Mark the membership as Centrally Managed. Only one membership type can be centrally managed.
Select the membership class you previously created.
Figure 6-2 Membership Type Details Screen
Set the External Database to the one with the same name as the outbound configuration that you previously created.
Set Membership Action to Auto Attach and select New Reservation.
Figure 6-3 Membership Handling Screen
Deselect Expiration Date Required.
Figure 6-4 Card Number Details Screen
Membership Levels
Figure 6-5 Membership Levels Screen
Parent topic: Gaming Integration Configurations
