4 Prerequisites
Application Versions
To use the Gaming Integration component, you must comply with the minimum required versions indicated in the table below:
Table 4-1 Application Versions
Application | Minimum Version | Comments |
OPERA Cloud |
22.5 |
This is the minimum version supported for gaming integration. |
nConnect |
1.8.4 |
Only applicable if your PTS is provided by Aristocrat. |
ADI |
8.X |
Only applicable if your PTS is provided IGT. |
System Requirements
When integrating two different applications where one application runs in the cloud and the another runs on-premise, there are some infrastructure and networking requirements that must be met to allow enable this cloud to on-premise integration.
Because OPERA Cloud runs in OCI (Oracle Cloud Infrastructure) and your PTS is predominantly running in your datacenter (either directly or via a hosting agreement), you must have your datacenter configured to enable OPERA Cloud to invoke APIs from your PTS that are unavailable through the internet.
The Oracle Hospitality Connectivity Agent for Gaming Integration is software developed by Oracle to run on your infrastructure. It is responsible for the integration between OPERA Cloud and your on-premise Gaming PTS. This Connectivity Agent for Gaming Integration is software developed by Oracle to run on your infrastructure.
