2 Prerequisites
Application Versions
To use the Gaming Integration component, you must comply with the minimum required versions indicated in the table below:
Table 2-1 Application Versions
| Application | Minimum Version | Comments |
OPERA Cloud |
22.5 |
nConnect |
1.8.4 |
Only applicable if your PTS is provided by Aristocrat. |
ADI |
8.X |
Only applicable if your PTS is provided IGT. |
SYNKROS SSB |
4.0.10 |
Only applicable if your PTS is provided by Konami. |
Infrastructure Prerequisites
To integrate OPERA Cloud with your Patron Tracking System (PTS), certain infrastructure and networking requirements must be met.
Since OPERA Cloud runs in OCI and your PTS is primarily running in your datacenter (either directly or via a hosting agreement), some configurations are needed within your datacenter to enable OPERA Cloud to invoke APIs from your PTS.
For more information, refer to the Connectivity Agent Hardware Sizing Guide.
