Membership Management
For details on completing the following configurations, refer to Guest Loyalty Programs in the OPERA Cloud Services documentation.
Membership Class
To properly use these gaming operations, you must have a membership class flagged as "Loyalty Program." For details on creating membership classes, refer to Configuring Membership Classes in the OPERA Cloud Services documentation.
Only one membership class can be flagged as “Loyalty Program.”
Figure 6-1 Membership Class Screen
This image shows the Membership Class screen.
Membership Type
To execute gaming operations with the IGT system, you must create a PTS membership type with the name "PTS."
The name of this Membership Type must be entered exactly as "PTS."
For details on how to create a membership type, refer to Configuring Membership Types in the OPERA Cloud Services documentation.
For the membership type details:
  1. Mark the membership as Primary.
  2. Mark the membership as Centrally Managed. Only one membership type can be centrally managed.
  3. Select the membership class you previously created.
Figure 6-2 Membership Type Details Screen
This image shows the Membership Type Details screen.
For the Membership Handling:
  1. Set the External Database to the one with the same name as the outbound configuration that you previously created.
  2. Set Membership Action to Auto Attach and select New Reservation.
Figure 6-3 Membership Handling Screen
This image shows the Membership Handling screen.
For Card Number Details:
  • Deselect Expiration Date Required.
  • Deselect Allow duplicate card numbers.
Figure 6-4 Card Number Details Screen
This image shows the Card Number Details screen.
Membership Levels
Once the membership type is configured, add your Membership Levels to this Membership Type. The values on the below image is just for illustration purposes. Your Hotel/Casino will have its own Membership Levels already defined by the business.
Figure 6-5 Membership Levels Screen
This image shows the Membership Levels screen.
