System Requirements
When integrating two different applications where one runs in the cloud and another runs on-premise, there are some infrastructure and networking requirements that must be met to run a software component that will allow this Cloud to On-Premise integration to happen.
Because OPERA Cloud runs in OCI (Oracle Cloud Infrastructure) and, predominantly, your PTS is running in your datacenter (whether directly or via a hosting agreement), you will need to have some configuration done within your datacenter in order to allow OPERA Cloud to invoke APIs from your PTS that are not available through the internet.
The Oracle Hospitality Connectivity Agent for Gaming Integration is software developed by Oracle to run on your infrastructure. It is responsible for the integration between OPERA Cloud and your on-premise Gaming PTS. This Connectivity Agent for Gaming Integration is software developed by Oracle to run on your infrastructure.
