4 Prerequisites
Application Versions
To use the Gaming Integration component, you must comply with the minimum required versions indicated in the table below:
Table 4-1 Application Versions
Application Minimum Version Comments
OPERA Cloud
23.5
This is the minimum version supported for gaming integration.
nConnect
1.8.4
Only applicable if your PTS is provided by Aristocrat.
ADI
8.X
Only applicable if your PTS is provided by IGT.
Light & Wonder CMP
13.0.11.5
Only applicable if your PTS is provided by Light & Wonder CMP
