4 Prerequisites
Application Versions
To use the Gaming Integration component, you must comply with the minimum required versions indicated in the table below:
Table 4-1 Application Versions
| Application | Minimum Version | Comments |
OPERA Cloud |
23.5 |
This is the minimum version supported for gaming integration. |
nConnect |
1.8.4 |
Only applicable if your PTS is provided by Aristocrat. |
ADI |
8.X |
Only applicable if your PTS is provided by IGT. |
CMP |
CMP 13.0.11.5 - Envoy 2.0 |
Only applicable if your PTS is provided by Light & Wonder |
ACSC |
ACSC 13.6.8.2 - Envoy 2.0 |
ENGAGE |
L&W Envoy 2.0.7.0 |
