10 Viewing Changes Logs
Prerequisites for Viewing Changes Log
The Changes Log provides a history of user activity. You can view the activities such as the creation or update of an enterprise template and custom template, adding or updating, and approving of configuration.
Change log entries are purged 365 days after the activity date.
Tip:
Enter any text in the Search field for a wildcard search.
  1. From the Side menu, select Changes Logs.
  2. Enter search criteria and click Search.
