12 Configuring Enterprise Settings
Prerequisites for Enterprise Settings
If different global configuration is required across your enterprise, enable the option to configure multiple enterprise templates. Activating this option requires that all properties of one Chain Code are associated to the same Enterprise Template.
Enabling Multiple Enterprise Templates
This option cannot be reverted once activated.
  1. From the Side menu, select Enterprise Settings.
  2. Select the Enable the Creation of Multiple Enterprise Templates checkbox.
  3. Click Save.
