| Oracle Hospitality APIs |
You can access examples of the currently supported Asynchronous
API operations categorized by Module in the provided Postman collection. |
Oracle Hospitality Postman Workflow collections
| Configuring External Systems |
All asynchronous operations require you to create an external
system. Oracle Hospitality OPERA Cloud requires this information to
identify the recipient of the request. This document explains the
step-by-step procedure to create an external system. |
| OPERA Cloud Rate Code User Guide |
Rate Codes form the core of OPERA Cloud reservation and rate
process. Rate codes are used to define the various prices for each
room type over a particular date range or rate season. Refer to this
document for additional details. |
About Rate Codes
| Rate Management User Guide |
Rate Management provides all the tools you need to effectively
define and manage the rate structures for your hotel. Some of the
things you can set up in Rate Management include rate codes, rate
classes, rate categories, display sets, rate strategies, and yield
management integration. Refer to this document for additional details. |
About Rate Management
| OPERA Cloud Sell Limits User Guide |
Sell Limits let you control room availability at your property.
You can configure sell limits from the Property Availability screen
in the Inventory section. Refer to this document for additional details. |
About Sell Limits
| OPERA Cloud Hurdle Rates User Guide |
Revenue Management (yield) solutions calculate the actual hurdle
rates that OPERA Cloud compares against. Refer to this document for
About Hurdle Rates
| OPERA Cloud Restrictions User Guide |
Restrictions help you manage occupancy and revenue (RevPAR)
by defining the conditions under which specific rates, room types,
and/or room classes are available to sell for new reservations. Refer
About Restrictions
| OHIP Digital Learning |
The learning path will provide an overview of the benefits,
highlight features, and provide instruction on the fundamentals of
OHIP. |
Oracle Hospitality Integration Platform (OHIP) for
Integrators Learning Path
