Errors
Table 12-5 Potential Streaming API Errors and Fixes
| Error Returned | How does this Happen? | How to Fix | Error Type |
429 Too Many Requests |
Sending more than 150 requests to upgrade to WebSocket and sending the requests within 2 minutes from the same application. |
Retry after 2 minutes. |
HTTP |
499 |
The client disconnected before the server was able to send a response to the initial HTTP upgrade, so the WebSocket was not opened. |
Ensure your calling architecture is leaving the connection open long enough for the server to reply. |
HTTP |
1000 Normal Closure |
The WebSocket was disconnected by the caller |
Reconnect from the Authentication message. |
WebSocket |
1001 Going Away: Going away |
Maintenance by Oracle |
WebSocket |
1006 Abnormal Closure: Abnormal Closure |
Connection broken |
Wait 4 seconds and then reconnect from the Authentication message. |
WebSocket |
Error: Unexpected server response: 400 |
Incorrect key or URL |
HTTP |
4400 Error: Bad Request - Invalid GraphQL Subscription |
Invalid field in subscription message |
WebSocket |
4401 Error: Unauthorised - Invalid credentials |
Invalid credentials sent in the Authentication message |
WebSocket |
4403 Error: Forbidden - You are not authorized to access this resource |
Invalid chainCode in subscription message |
WebSocket |
4406 Error: Subprotocol not acceptable |
Failing to include the WebSocket protocol header. |
Include the header "Sec-WebSocket-Protocol: graphql-transport-ws" |
WebSocket |
4408 Error: Disconnect |
Connection initialization time out |
Send the Authentication message within 5 seconds of opening the connection. |
WebSocket |
4409 Too Many Requests |
More than one client or process is trying to consume events from the same gateway using the same application key and chain code. This often happens in the following circumstances:
Retry after 2 minutes. Ensure that only one client or process consumes events from a given gateway using a given application key and chain code. Ensure that you send the Complete message before disconnecting from the WebSocket. |
WebSocket |
4429 Error: Too Many Requests |
Resending the subscription message when the connection is already open Resending the connection_init message when the connection is already open |
The WebSocket connection is already open, so it cannot be reopened. Look for the connection_ack message and do not resend connection_init if you have received a connection_ack. |
WebSocket |
4500 Server Error - No configuration found. If this problem persists, contact Oracle Customer Support at the Customer Support Portal. |
A Subscribe message was sent but either there are no events subscribed for this application, or the subscription is not approved by the environment owner. |
Check that the application is subscribed to events and shows as approved for that environment. |
WebSocket |
4500 Unable to find configuration between Application, Chain, and Environment. Please ensure your application has access. If this problem persists, contact Oracle Customer Support at the Customer Support Portal. |
A piece of internal configuration might be missing. |
Ensure your application is approved to consume events and that the URL you are calling is a streaming enabled gateway. If the problem persists, contact Oracle Customer Support at the Customer Support Portal. |
WebSocket |
4500 Internal Server Error received 6 minutes after sending the subscribe message. |
When subscribing, the consuming application should wait up to 6 minutes before receiving any events. If the subscription is valid and an internal issue has occurred, this message is received 6 minutes after sending the subscribe message. |
Reconnect and send the Authentication message and then send the Subscription message. |
WebSocket |
4501 Socket closed with error 4501 Not Supported Environment for subscriptions |
Connecting to an environment that does not support streaming Business Events. |
Ensure the environment shows as "Streaming Enabled" on the Environments tab of the developer portal. Streaming Business Events from OPERA requires a minimum of OPERA Cloud version 22.3.0.1. |
WebSocket |
4504 Socket closed with error 4504 Service Timeout |
This error occurs when the OCI Streaming Service goes down for more than 30 seconds. |
Try again after 15 seconds. If this problem persists, contact Oracle Customer Support at the Customer Support Portal. |
Websocket |
