Github and Postman Collections
Oracle Hospitality has a Github repository containing both Oracle Hospitality REST API specifications and accompanying Postman Collections.
You can access Github and locate the REST API specifications and Postman Collections at the following URL: https://github.com/oracle/hospitality-api-docs.
REST API Specifications
In the rest-api-specs folder in Github, you can view the published V1 APIs for OPERA Cloud and/or download the json specifications for the Oracle Hospitality APIs.
Postman Collections
In the postman-collections folder in Github, you can download and use the Postman Collection to help you get you started with our APIs and become more familiar with using them. The postman-collections folder contains the following content:
  • Postman collections with many different API call samples on how to perform different functional workflows (for example, digital check-in and checkout).
  • Postman Environment defining the main environment variables required to use the postman collections against our Hospitality APIs. Ensure you update this file with the relevant credentials and data for the environment to which you are connecting.
  • Document describing the different workflows supported in the postman collections.
The Postman collection is also available at the following URL: https://www.postman.com/hospitalityapis/workspace/oracle-hospitality-apis/overview.
Setting Up Your Postman Collection
To start calling the APIs, proceed to set up a postman environment collection using the below information. You might want to configure one environment collection for UAT and another one for Production as the variables will differ.
Table 8-8 Information for Postman Environment Collection
Hostname
This is the API gateway URL that can be viewed by logging into the Developer portal and viewing the environments tab.
CLIENT_ID & CLIENT_SECRET
The Client ID obtained from the OHIP Developer portal. See Viewing the Client Secret for details.
Enterpirse Id
The Enterprise ID against which you want to perform actions (for example, obtaining reservation data).
Scope
The scope variable representing the permissions of the client for authorization.
AppKey
The application key that was previously obtained. See Viewing Application Details for the specific steps.
HotelId
The Hotel ID against which you want to perform actions (for example, obtaining reservation data).
Once you have added these values into your postman environment, you can begin to call the oAuth Token. If everything is set up correctly, OHIP will respond with a HTTP 200 OK response, including the oAuth token. Now you can proceed to try out the collections as required.
Avoid uploading API secrets or tokens to Postman or GitHub. Public sharing may expose sensitive data.
GraphQL Specifications
In the graphql folder in Github, you can view and/or download the json specifications for the Streaming and Data APIs.
