Input Arguments Explained
Table 8-3 Date Inputs
Input Argument Description
_eq Equals. Accepts one date value.
_ne Not Equal. Accepts one date value.
_in In. Accepts a list of dates.
_nin Not In. Accepts a list of date values.
_gt Greater Than. Accepts one date value.
_lt Less Than. Accepts one date value.
_gte Greater than or equal. Accepts one date value.
_lte Less than or equal. Accepts one date value.
_btn Between. Accepts 2 dates – start and end dates.
_isNull Is Null. Accepts a Boolean value.
Table 8-4 String Inputs
_eq Equals. Accepts one string value.
_ne Not Equal. Accepts one string value.
_in In. Accepts a list of strings.
_nin Not In. Accepts a list of string values.
_gt Greater Than. Accepts one string value.
_lt Less Than. Accepts one string value.
_gte Greater than or equal. Accepts one string value.
_lte Less than or equal. Accepts one string value.
Table 8-5 Float Inputs
_eq Equals. Accepts one float value.
_ne Not Equal. Accepts one float value.
_in In. Accepts a list of float values.
_nin Not In. Accepts a list of float values.
_gt Greater Than. Accepts one float value.
_lt Less Than. Accepts one float value.
_gte Greater than or equal. Accepts one float value.
_lte Less than or equal. Accepts one float value.
_btn Between. Accepts 2 floats – start and end floats.
