Keyboard Only Users
When you log in to the Oracle Hospitality Developer Portal and go to the APIs page, you can use the keyboard keys to bring the focus to the Early Adopter message for Early Adopter APIs.
  1. On the Early Adopter APIs panel:
    1. Press the Tab key in any of the rows on the APIs page.
    2. Press the Tab key and select the highlighted text for the Early Adopter and then press F6. The content is highlighted.
    3. Press the Tab key to select the email address in the highlighted text. To send an email, press Enter. The selected email address opens in your default email client.
    4. Press the Esc key to let go of the pop-up text.
  2. To copy an application key using keyboard keys:
    1. Press the Tab key to move to the list of applications while on the Applications page.
    2. Press the Arrow keys to move from one application to the next.
    3. Press F2 to select an application.
    4. Press the Tab key to select Copy or to select View Details.
    5. Press Enter to
      • view the application details while on View Details.
        or
      • copy the application key to the clipboard while on Copy.
  3. For users who can view Early Adopter APIs, tab to the early adopter API banner and use the below keyboard commands.
    Table 16-1 Keyboard Commands for Early Adopter API Users
    Target Key Action
    Focus within Popup
    Tab or Shift + Tab
    Navigate the content of the popup. Close the open popup if there are no tab stops in the popup.
    F6
    Move focus to the launcher for a popup with modeless modality. Close the open popup if the modality is modal.
    Esc
    Close the open popup.
    Popup Launcher
    F6
    Move focus to the first tab stop within the open popup. If there is not a tab stop within the content, focus is established on the popup.
    Side Filters
    Search bar
    Press Tab once
    Press Tab again when focus is set on side filters
    Move focus to side filters.
    Move focus from side filters to search bar.
    Category
    Up and Down Arrows
    When focus is set on side filters on any category, you can use the arrow keys to move up or down a category (for example, API Lifecycle, Methods).
    Check boxes
    F2
    Press F2 to move within a category and access the check boxes.
  4. Tab to the data visualization chart to navigate between the data points on the Analytics tab.
    Table 16-2 Keyboard Commands for Data Visualization Chart
    Key Action
    Tab
    Move focus to the next element.
    Shift + Tab
    Move focus to the previous element.
    Up Arrow
    Move focus and selection to the previous data item.
    Down Arrow
    Move focus and selection to the next data item.
    Left Arrow
    Move focus and selection to the previous data item (on left).
    Right Arrow
    Move focus and selection to the next data item (on right).
