OPERA Xchange Interface (OXI)
The OXI Interface works on an asynchronous pattern which follows the below flow:
  1. A message is sent from an external system to OXI.
  2. The message sits in a queue.
  3. The message is processed.
  4. A record is inserted or updated in OPERA Cloud.
Once processed, a response message is returned to the external system, and it again sits in a queue until processed. This same pattern occurs for messages being generated from OPERA Cloud to an external system. The REST APIs work on a synchronous pattern. Conforming to REST architecture, the APIs allow for interaction with RESTful web services.
The REST APIs use JSON formatting.
You can move your integration from OXI to REST and even enhance it as there is greater functionality available with the REST APIs.
OXI Outbound Messages
For messages sent from OPERA Cloud to an external application, the REST APIs utilize the same Business Event functionality as OXI. Therefore, the same data can be triggered from OPERA Cloud. There are two approaches available for use: polling for Business Events using getBusinessEvents operation or using streaming services. For more information on property Business Events available in OHIP, refer to the Business Events topic that explains both options in detail.
OXI Inbound Messages
Data from the external application to OPERA Cloud can be achieved using REST APIs. The below mapping table shows the OXI messages and shows the equivalent Property REST API to use.
Key Considerations
OXI can synchronize data between the two applications. For example, users could enter a date range of reservations, and a batch of resync messages are sent to the external system. This was often used when a hotel went live with a new interface, ensuring the external system had all the required data, including rates, inventory, restrictions, and so on. The REST Property APIs have Asynchronous APIs, which enable the user to send a REST request to OPERA Cloud for a significant amount of data (for example, 30 days of reservations). OPERA Cloud processes the request, collects all the data, and then allows the data to be fetched using the get request.
OXI provided the ability to map OPERA Cloud codes to external system codes, such as room type codes, rate codes, package codes, and so on. The REST APIs with OPERA Cloud no longer follow this approach, and codes must now be one to one. Alternatively, the external system would need to cater for mapping on their side and ensure that when posting a message to OPERA Cloud, the message contained the OPERA Cloud code(s).
OXI XML messages send a full object in XML format as opposed to business event messages (either pull or push approach), which send key value pairs in JSON format. You will receive a JSON message with the old value and the new value. For more information, see Interpreting the Event.
Rest APIs handle credit card data differently than OXI, which allowed tokenization of card data. With REST APIs, the consumer must perform a step to fetch the token from the Payment Service Provider (PSP) and then use that token in the reservation. This only applies to customers with OPI active.
Table 14-1 OXI to REST
Functional Module OXI Inbound Operation (External System to OPERA Cloud) REST API Operation REST Module
Activity
Create Activity
postActivity
ACT
Activity
Update Activity
putActivity
ACT
Activity
Delete Activity
deleteActivity
ACT
Activity
Fetch Activity
getActivity
ACT
Profile
New Profile
postProfile
CRM
Profile
Update Profile
putProfile
CRM
Profile
Delete Profile
deleteProfile
CRM
Profile
Merge Profile
postMergeProfiles
CRM
Profile
Create Relationship
postProfileRelations
CRM
Profile
Update Relationship
putProfileRelations
CRM
Profile
Delete Relationship
deleteProfileRelations
CRM
Profile
Lookup
getExternalProfiles
CRM-OUTBOUND
Profile
Download
downloadExternalProfile
CRM-OUTBOUND
Reservations
Add Reservation
postReservation
RSV
Reservations
Edit Reservation
putReservation
RSV
Reservations
Cancel Reservation
postCancelReservation
RSV
Reservations
Share Reservations
postCombineShareReservations
RSV
Reservations
checkout
postCheckOut
CSH
Reservations
checkin
postCheckIn`
FOF
Reservations
Cancel Checkin(reverse check in)
deleteCheckin
FOF
Reservations
Fintrx
postDepositPayment
CSH
Reservations
Turnaway
postTurnawayReservation
RSV
Reservations
Routing
putRoutingInstructions
RSV
Reservations
Reinstate
putReinstateReservation
CSH
Reservations
No Show
putReservationStatusToNoShow
BOF
Reservations
Reservation Trace
getTracesByReservation
RSV
Reservations
Waitlist Reservation
postReservation
RSV
Reservations
Reactivate Waitlist Reservation
putReservation
RSV
Reservations
Room Move
moveInHouseGuest
FOF
Allotment (Group Blocks)
New Allotment
postBlock
BLK
Edit Allotment
putBlock
BLK
New Allotment - Header
postBlock
BLK
New Allotment - Header with Detail
postBlock
BLK
Allotment - Header - Status Change
putBlockStatus
BLK
New Block Reservation
postReservationByBlock
RSV
Update Block Reservation
putBlockReservations
BLK
Fetch Block Reservation
getBlockReservations
BLK
Update Block Grid Allocation
putBlockAllocation
BLK
Block Grid Wash
putBlockAllocationWash
BLK
Update Block Rates
putBlockRates
BLK
Update Block Pickup
putBlockStatusToOpen
BLK
Update Catering Status
putCateringStatus
BLK
Cancel Block
postCancelBlock
BLK
Hurdles
Hurdle
Block Asynchronous, Inventory Asynchronous, Par Asynchronous & Reservation Asynchronous Modules
ASYNC
Inventory
Inventory - KATOVER (overbook)
changeSellLimitByDate
INV
Inventory
Inventory - OOO
postOutOfOrderRooms
HSK
Stay Records
getStayHistory
CRM
Packages
Packages - New
postPackage
RTP
Packages
Packages - Edit
putPackage
RTP
Rates
Rate - Header
postRatePlan
RTP
Rates
postNegotiatedRates
RTP
Rates
postRatePlanPackages
RTP
Rates
Rate - Detail (Rate Set)
postRatePlanSchedules
RTP
Rates
Rate Strategy
postRateStrategy
RTP
RAVL (Rate Restrictions)
Restriction - Change
postRestriction
PAR
clearAllRestrictions
PAR
RAVR (Rate/Room Type Restrictions)
RAVR - New
postRestriction
PAR
RTAV (Inventory Snapshot)
RTAV
getHotelInventory
INV
Configuration
Configuration - RATE_CATEGORY
createRateCategory
ENTCFG
Configuration
New Item Inventory
postInventoryItems
EVMCFG
Configuration
New Item Load
postItemPools
EVMCFG
Configuration
Update Item Inventory
putInventoryItems
EVMCFG
Configuration
New Item Inventory Class
postItemClasses
EVMCFG
