Global Administration
Partner administrators can enable or disable certain optional platform capabilities from the Global Administration area of the Developer Portal. This centralized control allows organizations to manage the availability of selected features across their environments.
This capability can be used to manage optional features such as AI-powered functionality and other configurable platform capabilities.
Only users with the OHIPADMIN role can access Global Administration and manage feature settings.
Enabling a Feature
- Sign in to the Developer Portal.
- Navigate to Global Administration.
- Locate the Feature Controls section.
- Find the feature.
- Use the toggle button to turn the feature On.
Disabling a Feature
- Find the feature.
- Use the toggle button to turn the feature Off.
