Prerequisites
To use these APIs, you need the following product versions:
  • OPERA Reporting & Analytics (R&A) v24.4 (OAS version only)
  • Oracle Hospitality Integration Platform (OHIP) v25.3
  • OPERA Cloud Identity Manager as the Identity Platform
Additionally, Hoteliers are required to purchase one of the Reporting and Analytics Data Access add-on SKUs. Please contact your Oracle Representative for further details.
For partners, the existing Oracle Hospitality Integration Cloud Service subscription can be used, which is billed on a pay-per-call model unless the partner's usage is included in the SKU the hotelier purchased. For Partners, if the Hospitality Data APIs plan is not visible in your OHIP Developer Portal, send an email to hospitality-integrations_ww@oracle.com requesting access to the API Plan. Make sure to include the following details, which are found in the partner's OHIP developer portal:
  • Partner Name - The partner's name can be found on the title bar upper right-hand corner in the OHIP Developer Portal.
  • Cloud Account Name - This can be found in the URL for the OHIP Developer Portal.
  • UAT or Production or Both - Environment where it is needed for use.
We recommend registering a new application solely for Data APIs.
