Creating the External System
All asynchronous operations require you to create an external system. This is so Oracle Hospitality OPERA Cloud knows for whom to process the request. The external system code is in the path of every Asynchronous API.
If you already have an external system created by the OPERA environment owner, ask them to check whether step 4–d is complete. If complete, you can use this for the Asynchronous APIs.
Only the (Customer) OPERA environment owner can create an external system. They should follow this process:
