Deleting an Application
There are some important points to understand
when you want to delete an application:
You cannot delete an application if you have outstanding billing charges.
You cannot delete an application that is still subscribed to consume events using the streaming API. Unsubscribe from these events first, then delete the application.
Deletion cannot be undone, which means you will permanently remove any historical data and the app key will no longer work. Once you delete your app, you cannot restore it.
If you want delete your application, follow these steps:
