Managing Partner Connections
For customer environments supporting a Resource Owner Group authentication scheme (SSD), partner connections are approved by the chain administrator. This approval grants the WSACCESS role to the integration user.
Approving Partner Connections
When a partner submits a new request to add an integration user via the vendor registration portal, the chain administrator will approve the partner request in SSD after receiving an email from SSD.
Rejecting Partner Connections
To revoke access for a partner, the chain administrator must remove the WSACCESS role from the integration user within SSD.
Suspending a Partner Connection
If a partner connection is Suspended:
- The customer developer portal displays the partner's integration as 'SUSPENDED' in both the streaming approvals and OCIM approvals sections.
- The developer portal shows a 'SUSPENDED' status label as appropriate.
- The partner is unable to call APIs or consume Business Events. Any solution the partner offered by consuming the APIs would not work.
- If you have questions about the 'SUSPENDED' status of the partner, contact your partner.
