Reissuing an Application Key
A unique application key is created for each application,
which must be sent in the header of every request to Oracle Hospitality
APIs. You can reissue a key for an application from its Overview page.
Important:
When you reissue a key, requests to the Oracle Hospitality APIs that an application is subscribed to will fail until you send them the new key.- On the Oracle Hospitality Developer Portal, click Applications.
- On the Applications screen, select the application for which you want to reissue the key.
- Click View Details.
- Click the Show link to see the unique application key that is created for your application.
- Click the Reissue link.
- Click Reissue at the confirmation message prompt.
- The reissued application key appears instantly. Click Hide to hide the key.
