Viewing the Application Key
When in your application details, you can view and copy the application key. The application key is masked by default.
To view and copy your Application key:
- On the Oracle Hospitality Developer Portal, click Applications.
- On the All Applications page, select the application for which you need the application key.
- Click View details, and then under the Application Key, click Show or click Copy.
