Environment Requirements
OPERA Cloud Services: Ensure that you have an active subscription to OPERA Cloud Foundation.
Oracle Hospitality Integration Platform (OHIP): For customers, OHIP is included in the OPERA Cloud Foundation subscription. Partners require a subscription to the Oracle Hospitality Integration Cloud Service.
The OPERA Cloud environment must be version 22.3.0.1 or later.
Confirm that the OPERA Cloud environment has the Streaming API enabled as shown in the OHIP Developer Portal (the "Streaming Enabled" indicator). This is necessary for retrieving business events through the Streaming API. If it is not enabled, follow the appropriate steps below:
Gather Information
The below information is required to enable streaming. It can be found on the Environments card in the OHIP Developer Portal.
Customer Name: The customer's name can be found on the hotelier's Environments card in the OHIP developer portal and appears before the brackets on the card.
Customer Chain: The customer chain to be accessed. This can be found on the hotelier's Environments card in the OHIP developer portal and appears after the brackets on the card.
Environment Name: This can be found on the hotelier's Environments card in the OHIP developer portal and appears in brackets on the card.
Shared Security Domain: If the environment is a Resource Owner environment, this is the URL through which the integration user for the hotelier's environment was created.
EnterpriseId: If the environment is a Client Credentials environment, this can be found on the Environment card in the OHIP developer portal.
Customers
To get started with their first environment, customers must purchase the Oracle Hospitality Integration Platform Cloud Premium Remote Assistance SKU - 4 Hour Workshop (B93152) to engage with Oracle Professional Services and learn how to implement the Streaming API with best practices. As part of this training, Oracle Professional Services enables streaming for one UAT chain. Complete this training before raising a Technical SR to enable streaming for subsequent chains.
For additional environments, customers must raise a technical SR that includes these details.
Partners
Partners can initiate their testing in the partner sandbox environment. To gain access, request this in the partner Slack community. Partners should complete a successful streaming test by confirming that their code correctly receives Business Events and does not encounter errors either from OHIP or from downstream systems. This is not an Oracle validation, but a necessary assurance for both the partner and the hotelier before the partner accesses a hotelier's environment.
Following a successful streaming test, partners must open a Technical SR if they wish to get a customer environment UAT or Production environment enabled for streaming. The Technical SR must include the above details.
