Replaying Events
Scenario: Due to a temporary network outage, the CRM system missed several events emitted by the OHIP Streaming API. To ensure data integrity, the system must replay and process the missed events.
Conceptual Flow:
- Reconnection: Once the CRM system restores its connection to the Streaming API, it sends a subscription request with the "offset" parameter set to the last successfully processed event offset.
- Event Replay: The Streaming API replays all events from the specified offset, allowing the CRM system to process any missed events.
- Resumption of Near-Real-Time Processing: After catching up, the CRM system continues to process new events in near real time.
Replay logic is single-consumer and strictly ordered per stream. You are responsible for idempotency and duplicate suppression if retries/duplicates occur.
Figure 4-2 Flow Diagram
