Configuring External Systems
External Systems configuration defines the external systems integrated with OPERA Cloud. All validated partner solutions exist as External Systems to activate, configure and establish 2-way communication with OPERA Cloud
Additionally, you can define a new External Systems for any ad-hoc requirements to generate Business Events and share with an external system. Change your location to setup external systems for each property.
Once configured, user activity in OPERA Cloud triggers creation of business event XML messages for dequeue by external systems via OPERA Exchange integrations.
A Publisher is available to external systems to receive messages originating from another external system. To receive messages for events that originate outside OPERA Cloud, this relationship must be established. For example: If your property has two external systems: Yield System (YS) and Central Reservations (CRS), you can set up a relationship between these two external systems:
If the yield system would like to receive Reservation Business Events that are generated from both OPERA Cloud and the CRS system. The Publisher would then be set on the YS External System to receive the generated business events from the CRS external system.
If the CRS would like to receive Business Event messages when the Yield System sets restrictions or hurdle ratess, the Publisher would be setup on the CRS External System to receive the generated Business Events from YS external system.
Adding an External System
From the Administration menu, select Interfaces, select Business Events and then select External Systems.
Click New and enter the following details:
Property: Enter or select the property
Code: Enter a code for the external system.
Description: Enter a name of the external system.
External URI: This HTNG features is equivalent to the URN that will be sent to OPERA Cloud from an external HTNG vendor .
Sequence: Specify sequence in which the external system will display in the External Systems list.
Lookup: Click to enable if the external system supports profile lookup.
Additional Details:
Property: Enter or select the property.
Active: Click to activate.
To delete details, click vertical ellipsis and select Delete, click Delete to confirm.
Click Save.
Editing an External System
Enter search criteria and click Search.
Select the external system, click the vertical ellipsis Actions and select Edit.
Update details.
To delete Additional Details, click the vertical ellipsis Actions menu and select Delete, click Delete to confirm.
Click Save.
Deleting an External System
Select the external system, click the vertical ellipsis Actions menu and select Delete.
Click Delete to confirm.
Managing External System Publishers
Defines a list of subscribers (external system and property) who want to receive ongoing messages from the OPERA Cloud Business Events module.
Adding Publisher
Select the external system, click vertical ellipsis and select Publisher.
Click New.
Publisher: Select an external system from the list.
Property: Enter or select a property.
Click Save.
Deleting Publisher
Select the publisher, click the vertical ellipsis and select Delete.
