Configuring Property Interface Rights
Adding Property Interface Rights
                        From the Administration menu, select Interfaces, then select Property Interfaces.
                        Enter search criteria and click Search.
                        Select the interface, then click the vertical ellipsis and select Edit.
                        In the Interface Rights panel, click New and complete the following -
                              Category: Select the category to configure the right for. Selecting a category is optional, however if left blank, all available interface rights will appear in the Right field list of values.
                              Right: Select the interface right from the list
                              Code: Enter a unique code for the interface right. This field is limited to five characters. This value will appear on the Room Status or Group Bar/Unbar screens when working with the Interface Menu screen.
                              Description: Enter a short description of the interface right. This value will appear on the Room Status or Group Bar/Unbar screens when working with the Interface Menu screen.
                        Click Save.
Editing Property Interface Rights
                        In the Interface Rights panel, -
                              Select the right, then click the vertical ellipsis and select Edit.
                              Update configuration.
                        Click Save.
Deleting Property Interface Rights
                              Select the right, then click the vertical ellipsis and select Delete.
                              Click Delete to confirm.
