Using Group Rooms Control
The Group Rooms Control (GRC) page provides a daily summary of rooms set aside for blocks, including the number of blocked, contracted, picked up, and available rooms.
The summary section shows Status and Block Inventory.
In the Status section, you can view the summary for all statuses that apply to blocks during the date range being viewed and listed here.
In the Block Inventory section, you can view the summary for the following:
- Deduct Inventory: Blocked rooms are deducted from inventory.
Non Deduct Inventory: Blocked rooms not deducted from inventory.
Available Rooms: Total current house availability.
Available Rooms with Non-Deduct: Available rooms and not deducted from the inventory.
Pick Up tells you the day by day total available for pickup.
With the OPERA Cloud Sales and Event Management Premium Cloud Service, date-driven sell messages appear informing you of special offers and announcements. Multiple sell message are sorted by Begin date.
Click X to close the sell message panel.
OR
Click Sell Messages to toggle the Sell Message panel.
RP - Rate Protect (Red) and NC - Non Compete (Yellow) color indicators appear on applicable date columns.
Rate Protect indicates that no other groups should be booked using rates lower than those assigned to the block that is flagged as rate protect (available when the Lowest Rate Guaranteed OPERA Control is active).
Non-compete indicates that no competing accounts (accounts with the designated NC industry code) should be booked for same dates as the block flagged as non-compete (available when Non Compete OPERA Control is active).
Viewing Group Rooms Control
From the OPERA Cloud menu, select Bookings, select Blocks, and then select Group Rooms Control.
Enter a Property and Date, along with any other relevant information, then click Search.
Review the summary information and more details about each block in the search results.
Navigate to previous and future dates using the arrow buttons on the left and right sides of the horizontal date panel.
Click View Options to customize the information that appears in in the GRC. This option enables you to specify what information you would like to see in the summary section, detail level, and block summary sections of the screen. Select or deselect the options you wish to view, and then click Apply.
Click Collapse or Expand details for each block listed.
Depending on the View Options selected, the screen shows details of the rooms allocated to the block, including the number of blocked, contracted, picked up, and available.
Viewing Day Details on the Group Rooms Control
The GRC screen visually indicates dates with special events such as holidays or festivals taking place at or near your property. Refer to Using the Property Calendar.
Color indicators appear above the dates/day columns with special calendar events or Day Types setup.
RP -
Rate Protect and NC - Non Compete color indicators are also
displayed on applicable dates
Enter a Property and Date and any other search criteria and click Search.
Click the Day Details tab on the right side of the GRC to slide open the panel showing details about the Calendar events, Day Types, Rate Protect and Non Compete
Viewing Block Details from the Group Rooms Control
From the OPERA Cloud menu, select Blocks and then select Group Rooms Control.
Click a Block Code link to open a new window to view the Block Presentation page and make any changes to the block. For more information, see Managing Blocks.
Viewing Account Profile from Group Rooms Control
Click the Account link for a Block to open a new window to view the Profile Presentation page and make any changes to the sales account profile. For more information, see Managing a Sales Account Profile.
Creating Blocks from Group Rooms Control
Click the vertical ellipsis Actions menu and select Create Block or select (Create) Master Block or (Create) Master Allocation.
