Interface Resync - Blocks
- From the OPERA Cloud Exchange menu, select Interface Resync, and then select Blocks, from the drop down list.
- The Type and Property values are taken by default. Search and select an Interface that is to be resynced.
- Search and select Block Codes. You can select multiple codes.
- Enter a Period. From Start Date, select the first restriction start date for the resync. To Date, select the last restriction start date for the resync.
- Select All Active Records check box. Select if no other conditions are to be met except resyncing active records.
- Select the Unconverted Blocks check box.
- Select the Include Pickup Counts check box. Select only if the external system requires the pickup counts within the block message. This would be the case if you were resyncing a block without resyncing all its reservations afterwards. For initial cutover resync we do not recommend including the pickup counts, as reservations may be subsequently resynced and this automatically updates the pickup count in the blocks.
- Select the Include Cancelled Blocks check box. This could be needed for initial cutover resyncs where both systems should have all blocks including the cancelled ones, in case these may be reinstated.
- Click Resync History. Click this button to view when the resync option had last been executed and its status. This shows all resync options that have been executed.
- Click Resync. Click this button to start the resync process. This executes the resync according to the filters you have set.
