24 Interface Setup
Search page allows you to search by Property or by External
systems code. The recommendation is to search interfaces by Property
to get all the configured interfaces and search by Interfaces to get
the selected interface. Selecting multiple properties and interfaces
provides search results for all selected interfaces in the search
results.
               Searching an Interface
- From the OPERA Cloud Exchange menu, select Interface Setup , and then select Interface Setup from the drop down menu.
- From the Search panel, select Property and click Search.
- In the search results table, click the vertical ellipsis to Edit or Delete the setup. Search result table shows External System Property Code and External System Active/Inactive status.
- Click I Want To…, to update exchange capabilities. It allows you to configure the Business Events. It also allows you to activate External System if the external system is in an inactive state.
