Changing Function Space
Use this utility to change the code associated with a function space and update all relevant events.
From the Toolbox menu, select Utilities, select Data Management then select Change Function Space Code.
Property: Enter or select a property.
Code: Select a function space from the list.
New Code: Enter a new code for the function space
Click Change Function Space Code.
