Creating Master and Sub Blocks
Creating a Master Block
Master blocks are
indicated by this icon:
From the OPERA Cloud menu, select Bookings, select Blocks, and then select Manage Block.
Click I Want To . . .and select (Create) Master Block.
Complete the details for the master block. For more information, see: Creating a Block
After saving the master block, an initial sub block is auto-created.
Click Save or click Save and Go to Presentation to view the Master Block. For more information, see: Managing Blocks
Select the Master/Sub Block tab in Block Presentation to view the sub block.
You can now allocate rooms and set up catering events.
Creating a Sub Block
Sub blocks are indicated
by this icon:
- From the OPERA Cloud menu, select Bookings, select Blocks, and then select Manage Block.
- Enter search criteria for the master block and click Search.
- Select the master block in the search result, click I Want To . . . , and select (Create) Sub Block.
- On the sub block page, enter the following details:
- Property. Enter or select the property.
- Block Name. Enter the name of the sub-block.
- Start Date. Enter the sub block start (arrival) date.
- Night. Enter the number of nights.
- End Date. Enter the sub block end (departure) date.
- Block Code. Enter a block code. Click Get Default Block Code to generate a block code.
- Click Save or click Save and Go to Presentation to view the sub block.
Related Topics
Parent topic: About Master and Sub Blocks
