Configuring Display Sets
You can create Display Set codes so that reservation agents can find rate codes based on this special grouping of rates. Example of Display Sets could be such groupings as Best Available, Corporate, Discount, Promotional, Package etc
When creating rate codes you can select the applicable display set for the rate code. If no display set is selected for one or more rate codes, these rates will be grouped and displayed under a No Display Set grouping in Look To Book.
The Default Display Set OPERA Control determines which set of rates displays by default in Look to Book result.
Adding a Display Set
From the OPERA Cloud Administration menu, select Financial, select Rate Management, and then select Display Sets.
Click New and enter the following details:
Code: Enter a code for the display set.
Description: Enter a description for the display set.
Manage Translation: Click to open the multi-language descriptions screen and configure a translated description for each language.
Sequence: Enter a display sequence in lists.
Click Save
Editing a Display Set
Enter search criteria and click Search.
Select the display set in search result, click the Vertical Ellipsis and select Edit.
Update details.
Inactive: Select the make the display set inactive. Inactive codes will not display in list for selection
Click Save
Deleting a Display Set
If the display set is selected in rate code(s) it cannot be deleted.
Select the display set in search result, click the Vertical Ellipsis and select Delete.
Click Delete to confirm.
Parent topic: Rate Management
